The behavior has been reported in bug
1642711. Currently there are two workarounds that can fix this problem:
- Moving the added image out of the background images default folder:
1. Close all LabVIEW windows.
2. Move the image that was added to a different location, for example to the Windows default picture folder.
3. Open LabVIEW.
4. Follow the steps in the article
How to Set an Image as a Front Panel Background. Now the default images will be properly loaded.
5. While selecting the background image to use in the previous step, clicking the
Browse option in the
Background tab of the
Pane Properties and then navigating to the image that was moved outside the default folder, will load it correctly as well.
- Keeping the image that was added to the background images default folder:
2. Create a text file in the same default folder and input the image's name on the first line of the text file.
3. Save the text file with the same name as the image, then proceed to close the text file.
