"LabVIEW: (Hex 0x7): File not found" Error When Deploying VeriStand Project with XNET Database
Updated Feb 13, 2026
  • VeriStand
  • NI-XNET
I added some XNET hardware and its associated Database to my System Definition file in VeriStand. When I try to deploy to the Real-Time target I get the below error. How can I fix this?
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface
NI VeriStand: NI VierStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Incline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi <append>
This generic error can happen for one or various of the following reasons:
  • The XNET driver has not been installed in the Real-Time target.
  • The XNET driver version in the Real-Time target is not the same as the host PC.
  • The XNET hardware doesn't have an associated database or it has been moved/deleted.
Make sure you've followed the steps above, and if you're still having issues please contact NI for Support.
