If you want to load or save your configuration files, the IMAQdx Read Attributes (load) and IMAQdx Write Attributes (save) functions will help you with this task. These functions will load/save both the IMAQ and IMAQdx ICD files depending on where the attribute resides. As a reference, you can consider the Advanced Functionality with Attributes LabVIEW example.
