Can I Run Multiple Instances of FlexLogger on the Same Computer
Updated May 20, 2025
  • FlexLogger
I am designing a test system to use several data acquisition devices connected to the same computer and log the data with FlexLogger. Can I run several instances of FlexLogger on the same pc?
FlexLogger cannot currently run multiple instances on a single PC to run different tests with one acquisition device in each project. This would lead to resource conflicts between the separate instances of FlexLogger. Nevertheless, a single FlexLogger project can run a test acquiring data from different devices connected to a single computer at the same time, so there is no need to have several instances of FlexLogger open.
FlexLogger is recommended if the customer plans to collect, view in real-time and store data and does not need to control or interface with other equipment.
