Resistive NI SWITCH Module Measures Different Values Across Polarity
Updated Jun 20, 2023
  • PXI-2722
  • PXIe-4081
I am measuring a simple resistor using NI PXI-2722 and NI PXIe-4081. I realized that the value measured is different when the resistor is measured across two different polarity. What causes this behavior?
Generally, this behavior is expected across resistive switches/ relay. This behavior is caused by the thermal emf and offset voltage.
When measuring across polarity, the configuration is lead to typical channel accuracy and the accuracy is ~1% across channels in either polarity.
Do take account for thermal emf while measuring with resistive NI SWITCH module and NI DMM or replace the resistive NI SWITCH module into a non-resistive NI SWITCH module.
