Install LabVIEW Full Development System On Raspberry Pi 4 Model B
Updated Oct 21, 2021
Other
I have installed CentOS onto my Raspberry Pi 4 Model B, but when I try to install the LabVIEW development environment, I get an error as follows:
"The LabVIEW version is not compatible with the hardware architecture"
Why does this happen?
Since the Raspberry Pi 4 Model B is has an SoC built on the ARM architecture i.e. the "Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC", it is not a compatible device for installing the LabVIEW Full Development environment.
For details on the compatible OS and CPU architectures, refer to the LabVIEW readme document. For the procedure integrate and control Raspberry Pi with LabVIEW, refer to this article on using Raspberry Pi with LabVIEW.
