이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Version(s) of Microsoft Visual C++ Runtime Installer Included in LabVIEW Runtime
Updated Mar 8, 2024
  • Third Party Add-Ons
  • Which version of Microsoft Visual C++ Runtime installer is included in all LabVIEW Runtime?
  • I need to include VC++ 2013 Runtime Installer into LabVIEW-built installer, but there is no VC++ 2013 Runtime as an option in additional installer section, how can I include it?
  • There is only NI VC2015 Runtime installer shown under LabVIEW 2020 Runtime, can I use other version of VC++ installer? Are they compatible?
Each version(s) of Microsoft Visual C++ Runtime Installer that are included by default in LabVIEW Runtime are listed as below:
LabVIEW Runtime VersionMSVC Runtime Version
NI VC2015 RuntimeNI VC2010MSMsNI VC2008MSMsNI VC2005MSMs
2024
2023
2022
2021
2020
2019
2018
2017
2016
2015
2014
2013
2012
2011
2010
2009
       Included
Both LabVIEW and Microsoft Visual C++ are two independent software, so there is no compatibility issue between both software. If the Microsoft Visual C++ Runtime Installer needed isn't included in the LabVIEW runtime installer used, you will need to download Microsoft Visual C++ Runtime Installer from Microsoft Official Website then you can manually add the Microsoft Visual C++ Runtime Installer into your LabVIEW installer. You can refer to Including Third Party Installers and Drivers in a Labview Installer.
