Each version(s) of Microsoft Visual C++ Runtime Installer that are included by default in LabVIEW Runtime are listed as below:
LabVIEW Runtime Version | MSVC Runtime Version |
NI VC2015 Runtime | NI VC2010MSMs | NI VC2008MSMs | NI VC2008RTE |
2010 | | | | |
2011 | | | | |
2012 | | | | |
2013 | | | | |
2014 | | | | |
2015 | | | | |
2016 | | | | |
2017 | | | | |
2018 | | | | |
2019 | | | | |
2020 | | | | |
2021 | | | | |
Both LabVIEW and Microsoft Visual C++ are two independent software, so there is no compatibility issue between both software. If the Microsoft Visual C++ Runtime Installer needed isn't included in the LabVIEW runtime installer used, you will need to download Microsoft Visual C++ Runtime Installer from Microsoft Official Website then you can manually add the Microsoft Visual C++ Runtime Installer into your LabVIEW installer. You can refer to
Including Third Party Installers and Drivers in a Labview Installer.
