Verify two chassis whether are synchronized or not by refer t0 (time acquired of first data) in timestamp.
If both devices' task t0 are same, it means both chassis are synchronized.
- In DAQmx Read.vi, select Analog >> Multiple Channels >> Multiple Samples >> 1D Waveform (Duration).
- Right click at output data >> Create indicator.
- Compare t0 for both devices.
