Troubleshooting FlexLogger Guide
Updated Feb 19, 2026
  • FlexLogger
This guide is to help you get started with troubleshooting FlexLogger™, explaining common troubleshooting steps and questions from installing the software to using it with different hardware. There are several issue areas/topics that are linked out to other knowledge articles for general steps, questions and some specific situations and solutions.
This guide links to 5 other pages that each focus on one troubleshooting area/topic.
Important Note: This guide does not cover every possibility of troubleshooting and issue. Therefore, it should be used as a starting point and exploring the terminology to further search for solutions if they are not found.
Initial Troubleshooting Questions
To be efficient in the troubleshooting process, go through the following questions and note details of your issue and the context in a list:
  • What hardware is being used?
  • What version of software/drivers are installed?
  • What operating system is being used?
  • Getting a MAX Technical Support Report
    • Note: This is used by Technical Support and is a more formalized display of the first 3 bullet points and should only be obtained as necessary or when instructed.
  • How is the hardware connected? (What does the setup look like?)
  • What does the problem look like?
  • What is the intended use?
  • Where does the problem appear from?
Troubleshooting FlexLogger Guides:
Look to the following links for the topic area most similar to the issue. Follow the most appropriate link for more information and tools to help assist your troubleshooting of the problem. Examples of using the answers are listed towards the bottom of the page.
Example 1:
    • NI-9202
    • FlexLogger 2020 R2
    • Unknown
    • Unknown
    • Uncertain on how to access the filtering in FlexLogger
    • FlexLogger
Result 1: The question/problem is related to how to use a particular function of FlexLogger, therefore, “Interface Issues or “Is It Possible with FlexLogger?” should be the first place to look through.
Example 2:
    • Unknown
    • FlexLogger 2021 R1
    • Unknown
    • trying to install FlexLogger, using the NI Package Manager, but getting an error
    • Unknown
    • Package Manager installation
Result 2: The question/problem is related to the initial setup and installation of FlexLogger, therefore, “Issues Installing FlexLogger” would be the best place to start.
Next Steps
Moving forwards in your application, have a look at the FlexLogger Manual  for further guidance on getting started concepts, step-by-step instructions, and reference information for setting up your hardware and test configuration.
