Error Code : 5005 on VI Package Manager
Updated Sep 21, 2021
  • JKI VI Package Manager
  • LabVIEW SoftMotion Module
  • LabVIEW Real-Time Module
  • NI-RIO (Legacy)
Other
SDI Plug-in – Maxon Motor MAXPOS v1.0.2.5
I am receiving Error Code : 5005  when trying to install a LabVIEW add-on (SDI Plug-in – Maxon Motor MAXPOS v1.0.2.5) through my VI Package Manager.
Error 5005 on VIPM
Is there anything I can do to resolve this error?
The error can be caused by missing software or unestablished connection between the VI Package Manager and LabVIEW. Check the following steps to ensure everything is properly set up before installing your add-ons through VI Package Manager:
  1. Make sure that you are using a 32-bit version LabVIEW to connect to your VI Package Manager, 64-bit version LabVIEW is not supported by VI Package Manager.
  2. Make sure that your VI Package Manager is connected to your LabVIEW by referring to VI Package Manager(VIPM) cannot Connect to LabVIEW .
  3. Install LabVIEW Softmotion Module which is required for VI Package Manager to function.
  4. Install the required software including.
  • NI RIO, LabVIEW SoftMotion Module
Please refer to this VI Package Manager Website  to check for appropriate versions of add-on software to install.
Disclaimer: The Third-Party Add-Ons for LabVIEW on this page are offered by independent third-party providers who are solely responsible for these products. NI has no responsibility whatsoever for the performance, product descriptions, specifications, referenced content, or any and all claims or representations of these third-party providers. NI makes no warranty whatsoever, neither express nor implied with respect to the goods, the referenced contents, or any and all claims or representations of the third-party providers.
If the above solution does not help with eliminating your error, please reach out to Maxon Motor for technical support.
