KUNBUS Network Configurator Showing No Device Found
Updated Aug 30, 2021
  • PXI PROFINET Interface Module
  • PXI PROFINET
  • PXIe-1062Q
  • PXIe-8135
  • PROFINET for PXI
Other
I want to verify the network connection to use PROFINET communication in NI PXI PROFINET Interface Module with KUNBUS Network Configurator. I have installed PROFINET for PXI Driver on Windows 10 OS and connected port 1 to port 2 of the module in a loopback configuration. The device is detected in NI MAX but when I click the KUNBUS Network Configurator application, it is showing no devices found.
  1. To verify the network connection of PXI PROFINET Interface Module, connect the PC's or PXIe Controller's Ethernet port to the DF PROFINET IO Controller port. The green LED would be on once the connection is established.
Connection Diagram
  1. Run the KUNBUS Network Configurator application to display the network details of the controller port.
