LabVIEW users can access and use LabVIEW add-ons from VI Package Manager (VIPM) from JKI. With LabVIEW 2020 SP1 and later, LabVIEW restricted access to its installation folder to align with best practices recommended by Apple. However, this makes VIPM unable to directly install content into the LabVIEW folder on macOS.
If you are not using LabVIEW 2020 SP1 or later on a macOS, you can download and manage VIPM packages using the normal process without updating VIPM permissions.
MacOS users who would like to install VIPM Packages for LabVIEW 2020 SP1 or later should follow the steps below to configure VIPM and the LabVIEW folder to have the correct permissions. After adjusting permissions, users can download VIPM packages as normal.
