The LabVIEW Icon API allows users to programmatically generate or edit VI icons, templates, and text layers using LabVIEW Object-Oriented Programming . This API installs with LabVIEW, and can be found at C:\Program Files (x86)\National Instruments\<Your LabVIEW Version>\vi.lib\LabVIEW Icon API by default. Example implementations of the API can be found in the same location in the Examples folder, which can be used to get an understanding of the API's implementation and execute some common applications of the Icon API.
