VIs in Packed Library is Missing or Not Loaded
Updated Mar 31, 2025
  • CompactRIO Chassis
  • LabVIEW Real-Time Module
  • I can load the VIs from packed library in a project under my computer. However, when I add the packed library to project under Real-Time target, Not loaded is displayed beside the library and the VIs inside the library is missing as shown below:
not loaded issue
  • When I try to open a project that loads and calls a LabVIEW Packed Library, I get error Hex 0x625:
LabVIEW: (Hex 0x625) You cannot load a packed library built for a target or operating system different than the current target or operating system.
An error occurred loading VI '<Packed_Library.lvlibp: <VI Name>'
LabVIEW load error code 55: Could not load packed library.
The error is displayed in the following dialog box:
This issue occurs when the packed library is built and used under different system. Try to build the packed library under Real-Time target and add the built packed library under Real-Time target as shown below:
not loaded issue solution
To avoid this issue, if you build the packed library under Windows system, you should add the built packed library under Windows system. Similarly, if you want to use the packed library under Real-Time target, the packed library is required to build under Real-Time system.
