These issues are related to the corruption of the IVI driver. In order to troubleshoot the problem, try the following steps below:
1. Browse to the
IVI Foundation page and run the Cleanup Utility followed by repair of the IVI Compliance Package or install the IVI Shared Components or repair that can be found on that same IVI Foundation page.
2. If the first step did not solve the IVI problem then please try the steps mentioned in this manual:
IVI Configuration Server Configuration (Section 3.2) :
The Master Location property in the IviConfigStore class returns the full pathname of the master configuration store. It determines the name by reading the registry key
HKEY_LOCAL_MACHINE/SOFTWARE/IVI/CONFIGURATIONSERVER,
MasterStore, and, on Windows Vista 64, the registry key
HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node/IVI/CONFIGURATIONSERVER, MasterStore. Both values must match or an error is returned.
For the precise semantics, refer to Section 7.3.3 in the
IVI Configuration Manual.
By ensuring both of these keys existed and matched
the error should no longer appear.
