To get VBAI inspection step results in LabVIEW, you can use VBAI Interface - Get Inspection Results .vi, right click and create the
Indicator at Step Results terminal node. The step results will be display in the array of cluster.
The VBAI inspection below show the example to find 1D and 2D barcode :
The inspection step results in LabVIEW is shown in the picture below :
