In LIN communication program, you have to define LIN schedule so that it is not possible to do LIN communication without LIN schedule prepared. But by setting specific LIN Schedule and
RunMode property as
Once you can execute the LIN Schedule only once or other arbitrary timing and you do nothing in the other timing (do "empty" schedule periodically). See the following practice.
1. Prepare LIN schedule file. In this file, define at least three schedule property, Empty, For_Master, and For_Slave. In Empty schedule, no specific schedule is defined. In For_Master schedule, only schedule for Master is defined. In For_Slave schedule, only schedule for slave is defined.
2. In LabVIEW program, at initialize step, prepare schedule setting as to
RunMode setting for Empty schedule is set to be
Null and for For_Master and For_Slave schedule to be
Once. See the image below.
3, When you want to send Master header and receive the response from your DUT, execute something like below. When
RunMode is set to be
Once,
the designated schedule is executed only once and after the schedule is executed once then returns to the previously running schedule, in this case do nothing (Empty schedule).
