Run VBAI Inspection in LabVIEW
Updated Apr 17, 2026
  • Vision Builder for Automated Inspection
I have created a simple inspection in Vision Builder for Automated Inspection (VBAI) software. How can I run the inspection in LabVIEW?
To run a VBAI inspection in LabVIEW, make sure you have the VBAI LabVIEW Interface API installed. This is automatically installed when you install VBAI. To check if the API is present, right-click on the LabVIEW Block Diagram and search for Vision and Motion>>Vision Builder AI.
Follow the steps below to run a VBAI inspection in LabVIEW:
  1. Re-create or import the code snippet below:
  2. In the Path control, set the path of your VBAI inspection.
  3. Select the correct VBAI version in the Engine Version constant, for example VBAI 2019 (32-bit).
  4. Run the LabVIEW VI. An image of the inspection will be display as shown in the picture below.
