Access Error 404 When Connecting to NI ELVIS III From Measurements Live
Updated Apr 19, 2024
  • NI ELVIS
When trying to Connect to my NI ELVIS III board, through Measurements Live, I get the following error:
Access Error: 404 -- Not Found
Cannot open document for: /proxy-application.html
The error shows up in a pop-up window like the one below:
This error occurs because the software on the board was installed incorrectly, or the LabVIEW ELVIS III Toolkit is not installed on the board.
Please make sure you have the following software installed in your host computer before proceeding:
After ensuring that the above software is installed in your computer, please follow the steps below to fix this issue:
  1. Connect the NI ELVIS III Board to the computer over USB.
  2. Hold the RESET button on the NI ELVIS III board and release it when STATUS LED turns yellow. Wait for 20 seconds for the board to restart.
  3. Open NI Measurement and Automation Explorer (NI MAX) and find the NI ELVIS III board under Remote Systems.
    • If the board does not show under Remote Systems, right click on Remote Systems >> Troubleshoot Remote Discovery and follow the steps provided.
  4. Under the NI ELVIS III board in NI MAX, right click on Software >> Add/Remove Software >> Log into the board with your credentials. ​​​​​
  5. The LabVIEW Real-Time Software Wizard will pop up >> Highlight the NI ELVIS III XX.X software package.
    • If the ELVIS III is running a Linux RT System Image, the popup below will not resemble the image below. The NI ELVIS III Toolkit will appear in Add/Remove Software.
    • There is a known issue with NI Linux RT System Images 21.X which does not allow installing the ELVIS III Toolkit in the board, resulting in not being to connect to the boards. Install NI Linux RT System Image 2022 Q3 or later in order to be able to install the ELVIS III Toolkit in the board.
    • Ensure that the version of NI ELVIS III Software Bundle installed comes with one of these versions of LabVIEW and the associated version of the LabVIEW ELVIS III Toolkit.
  1. Click Next >> Make sure the LabVIEW ELVIS III Toolkit is checked.
  1. Click Next, and allow the software installation to finish.
  2. Wait until the board comes up back again.
  3. Open Measurements Live and try to re-connect to the board.
