Timing Violation Error using a NI FPGA FlexRIO CLIP - Requirement 0,00ns Missed
Updated Jul 7, 2020
  • PXI FPGA Module for FlexRIO
  • LabVIEW FPGA Module
In NI FlexRIO there are several CLIP directly usable like the SerDes Connector CLIP Reference.
Why do I get a Timing Violation Error using the CLIP nodes to access the Data?
The Timing Violation Error states a missed Requirement of 0,00ns by some ns.
For a CLIP node you must not use the different CLIP Properties mixed with Non-CLIP Properties in the same Node, nor the same SCTL.
