NI MAX Test Panel support was removed from the NI-HSDIO driver as of version 19.0. To achieve similar functionality, consider using shipping examples:
If you require the use of NI MAX Test Panels, you must first uninstall the newer version of NI-HSDIO on your system and then install version 18.5 or earlier.
