Error -63192: The Specified Device Was Not Found
Updated Aug 10, 2026
  • PXIe-5831
  • PXIe-5830
  • PXIe-5655
  • PXIe-5842
  • RFmx
  • InstrumentStudio
  • NI-RFSA
  • NI-RFSG
  1. Whenever I try to open the RFmx SpecAn Soft Front Panel to access my Vector Signal Transceiver (VST) device, I get the following error. Also, if I try to run the intermediate Self-Calibration for this device, I get the same message.
  1. I am seeing this error after moving my VST from one chassis to another. It is the same chassis model and slot number. When I try to initialize the device from LabVIEW using the RFSA/G Initialize API call, it gives me an error saying I have an invalid resource name, and to “use MAX to find proper resource name”. However, the LabVIEW resource name parameter matches the name in MAX. How can I resolve this?
This error is caused by a device configuration that remains in the software environment after system changes.
After the error occurs, perform the following steps to resolve the issue:
  1. Repair the NI MAX database using the steps described in Reset and Fix the Measurement & Automation Explorer Database File. This helps remove any outdated hardware configuration.
  2. Unassociate the LO from the PXIe-5842
  3. Rename and save the PXIe-5842 and PXIe-5655. If you want to keep the existing name, rename the device to temporary names and then change them back to their original names.
  4. Reassociate the LO.
If you need help renaming a device in MAX, refer to: How Do I Find or Modify My Device's Name?
