I have an application where I open an FPGA reference and then reserving a PXI Trigger Line.
When I execute the VI on my RT controller by clicking run (Interactive control) everything runs with no error.
But, when I build a Real-Time Application and deploy it to my system, the same code gives this error:
Error -63052 occurred at an unidentified location
Possible reason(s):
NI-RIO: (Hex 0xFFFF09B4) Trigger lines are not supported or enabled. For PXI, identify the controller and chassis using MAX.
