This is possible using the syntax below:
In the File Pathname: It is necessary to use the path where you installed Veristand, then, select the Veristand.exe file.
Argument Expression: It needs to contain the command and Veristand Project path.
- "/nivsprj " + "\" " + "path for the .nivsprj file"
