Add Additional Results Using the TestStand APIs from LabVIEW
Updated Oct 22, 2024
  • TestStand
How do I add additional results in LabVIEW using the TestStand API?
 To add additional results programmatically you can use the TestStand API, refer to the following steps:
  • Using the Sequence Context, you can get a the reference to the current sequence:
  • Using the GetStepByName method you can get a reference to the Step object you specify by name (in this document Test Step):
  • Using the Addtional Results and the Custom Results properties and the Insert method, you can add a custom additional result (in this document, we are adding a custom result called "Custom Result" with a value of "Notes - example". You can also specify an expression for example use RunState.Sequence.Main["Test Step"].Result.Status, to log the status of the current step).
  • Finally, close of the all references using the Close Reference Function:
The code (LabVIEW 2019) is provided below:
The resulting report should include your custom result:
You can also refer to other approaches as indicated in Adding Custom Data to a Report.
