How to Create/Modify a .mat File in LabVIEW?
Updated Mar 26, 2024
  • MATLAB
Other
MAT-File IO Library for LabVIEW
I am using both, LabVIEW and MATLAB to develop a software application. How can I read/write a .mat file in LabVIEW?
You have two alternatives to use .mat files in LabVIEW:
1. You could use the MATLABĀ® DataPlugin, After installing the dataplugin, you can use the LabVIEW Data Storage VIs to manipulate .mat files.
2. Another option is the MAT-File IO Library for LabVIEW, this is a third-party library not supported directly by National Instruments and distributed throught the VI Package Manager. After installing the library you can refer to the examples available in C:\Program Files (x86)\National Instruments\LabVIEW XXXX\examples\matio (XXXX,is your LabVIEW version)
For more information about dataplugins refer to Using DataPlugins with LabVIEW
