I am building an FPGA application that I will need to be able to communicate with it using other executables that I build in other programming languages such as Python, MATLAB, and others.
Is there a preferred and robust method to be able to do this?
Can I do this using ActiveX or .NET?
The FPGA in the cRIO is only accessible using the LabVIEW FPGA Module. This discard ActiveX or .NET.
A valid service agreement may be required, and support options vary by country.
