We recommend checking whether it is completely necessary to load the assembly from a remote location, since this could cause some security vulnerabilities on your system. If possible, place the assembly on a local directory on the machine running the test sequence. If you require to load the assembly from a network location follow these steps:
- Go to the installation directory for TestStand:
- For 32 bit TestStand C:\Program Files (x86)\National Instruments\TestStand 2019\Bin
- For 64 bit TestStand C:\Program Files\National Instruments\TestStand 2019\Bin
- Open SeqEdit.exe.config with a text editor (notepad for example)
- Add the following line to the “runtime” section
- <loadFromRemoteSources enabled= “true”/>
- The file should look like the image below
- Save the file and restart TestStand.
