VeriStand does not natively have a full merge function built into it. However, the projects can be merged in steps.
- Targets: In the VeriStand System Explorer, it is possible to select a target, go to Edit->Copy, open another System Definition file and Edit->Paste to insert the Target into the new system definition file.
- Aliases: Aliases can be exported via right-clicking Aliases -> Export Aliases, saving as an ASCII file and then imported via right-clicking Aliases -> Import Aliases in the new System Definition file.
- Scales: Scales can be imported via right-clicking Scales -> Import Scales in the new System Definition file and pointing to the correct file
- System Mappings: System Mappings can be exported and imported using System Configuration Mappings Explorer.
- Screens: To merge screens, go to File->Add File -> navigate to the screen and add this to the project. Ensure that the mappings are correct.
