The LabVIEW Add Vi in Project Dialog Does Not Appear
Updated Jun 25, 2020
I am using LabVIEW and when I open a VI and I create a project with the File>>Create Project option, I don't have this dialog:
But I need it to add the VI in my project. What can I do to enable this window?
You may have previously clicked on the "Do not show this dialog again". In order to enable the window, you can open the LabVIEW.ini file located inĀ C:\Program Files (x86)\National Instruments\LabVIEW 2019
In it, you should find those two lines:
DontShowProjectAddDialog=True
DontShowProjectAddDialogDoNotAdd=True
Delete those lines and the next time you will open LabVIEW, the window should appear.
