How to Check Tap Configuration for My Framegrabber
Updated Apr 1, 2020
Can the PCIe-1433 be configured to a 10-tap configuration? Table 2-1 in the specifications sheet only mentions the base, medium, and full configurations; however, it also notes that the extended full configurations support up to 80 bits of data.
Yes, the PCIe-1433 can be configured to 10-taps; you can check the Framegrabber Specifications for the NI Camera File Generator document online for available tap configurations for all NI framegrabbers.
You can also check for available tap configurations when you select the framegrabber via NI Camera File Generator and check the "Orientation" section.
