在LabVIEW中构建DLL时出现错误1
更新 Feb 21, 2023
我试图从我的LabVIEW项目中构建一个新的DLL,所有的VI都在工作,但是当我按下Build按钮时,出现以下错误:
Error 1 occurred at : Compile Dll Stub.vi ->
AB_Engine_DLL_Build_Stub.vi
Possible reason(s):LabVIEW:(Hex 0x1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Command requires GPIB Controller to be Controller-In-Charge.
我怎样才能解决这个问题?
在构建规范中,您必须选择“Advanced”,并且需要取消选中“Include a type library for TestStand or Call Library Nodes”
