DIAdem DAC Task Aborts With Licensing Error Message
Updated Oct 23, 2026
  • DIAdem
  • DIAdem DAC Kit
  • DIAdem DAC Bundle
In DIAdem DAC I created a DAC block diagram where I acquire data from a third party device. But every time I start the DAC task, I get an error message which states that there is no valid license and the measurement is aborted:
But I have already a license for the DIAdem DAC module and it is properly licensed in the NI-License Manager. What can I do in order to get my program running?
This error is not related with the licensing of DIAdem or the DAC module itself. It results most likely in a not appropriately licensed third-party driver. Please check if the driver for the third-party device is licensed and not expired and contact the vendor or distributor of the driver if necessary.
For HBM / QuantumX Users:
The issue might be related to the third-party driver such as the HBM DIAdem Driver. Third-party drivers that integrate hardware (Quantum X) into DIAdem (such as the HBM DIAdem Driver) are developed and licensed independently by HBM. Please contact HBM-Support for further assistance.
For HBM/QuantumX users, one common reason for this issue is that the HBM DIAdem Driver was running on a 30-day evaluation/demo period that has expired. When the evaluation period expires, DIAdem DAC may abort the measurement and display the error above.
After a valid HBM DIAdem Driver license is purchased and applied, the measurement can run normally.
There could also be other driver licensing or configuration reasons. Contact HBM-Support for further assistance.
