NI-9881 CANopen Module in cRIO-906x Chassis
Updated Feb 25, 2020
I want to use NI-9881 CANopen module and other C-Series Modules in cRIO-906x chassis.
However, NI-MAX can not detect NI-9881 when I create a LabVIEW project file with the configuration below.
Real-Time Scan Resources: NI-9881 CANopen Module
FPGA Devices : C-Series Modules.
(I have compiled empty vi with is under FPGA target.)
I was able to see NI-9881 after the compilation when I used it with cRIO-907x chassis.
Can NI-9881 be used with cRIO-906x chassis? If Yes, how can I use it?
Yes, you can use NI-9881 with cRIO-906x chassis.
You can follow the steps below.
1. Add NI-9881 under Real-Time Scan Resources
2. Add C-Series Modules, which you wish to use, under FPGA Target
3. Make sure that Chassis is in LabVIEW FPGA Interface Mode
Right Click Chassis(cRIO-906x) >> Property >>LabVIEW FPGA Interface
4. Compile the empty.vi under FPGA Target
Please refer Getting Started with CompactRIO for the details.
6. Deploy
Right Click  Chassis(cRIO-906x) >> Deploy
7. Now you can see NI-9881 in NI-MAX
