Dynamically Obtaining Message IDs for TestStand UI Messages
Updated Jan 31, 2020
  • TestStand
Programming Language
  • LabVIEW G
  • C# .NET
  • Visual Basic .NET
  • C
  • C++
I want to use UI Messages for the communication between TestStand and my TestStand User Interface (UI). However, my TestStand UI might be replaced by another TestStand UI so I don't want to use static message IDs for my UI Messages to reduce coupling. What can I do?
TestStand can obtain a message ID for your UI Message dynamically. You can use the RegisterUIMessage Method to obtain a new message ID or get the message ID for an already registered UI Message.
This method of defining message IDs uses the message names to identify the message ID from it. This requires a very careful design of the message names to avoid sending unintended messages.
