NI-DMM/Switch Express VI Gives Error "Unable to View Properties"
Updated Jun 16, 2020
  • NI-DMM
I'm using the NI-DMM/Switch Express VI in my LabVIEW application, when I try to open and configure the properties of it, I get the message "Unable to view properties"
The solution for this problem is to install a NI-DMM driver that is a lower version then 19.0, because NI-DMM 19.0 driver drops support for Express VIs in LabVIEW.
Existing code created with earlier versions of NI-DMM that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box.
The additional solution, on how to reconfigure this Express VI is, to right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code, that you can configure on the block diagram.
