NI Camera File Generator : Fatal Error Occurred at
Updated Feb 25, 2020
  • Frame Grabber Device
  • Vision Development Module
I am creating Camera File with NI Camera File Generator. I got fatal error as shown below when I try to copy an attribute.
How can I copy the attribute without the error?
Fatal error occurred at:
The pointer provided is either NULL when it should not be, or is non-NULL when it should be NULL.
You can solve this problem by selecting the correct attribute and copying it.
For example, you can select Attribute_1(the list of the attribute) and click Copy as shown below.
You will receive the error if you select 789(the element of the attribute list) and click Copy as shown below.
This error occurred because of the unexpected pointer information of the attribute.
