Speed up My EMVco Pcd Analog Test Suite
Updated Mar 25, 2020
  • Micropross Accessories
Other
SW:
  • EMVco PCD Analog 4.0.3 and later version
  • MPMANAGER 3.7.2 and later version
My EMVco PCD analog Test Suite slow down after few hours of run. Is there a way to speed up the Test Suite?
In Test Suite Options\Others you have the option Disable analog graph.
  • If you set it to YES, test suite execution will not display analog graph at all, consequently png pictures are not produced. This will increase execution speed of long sessions.
  • If you set it to NO, analog graph will be displayed, png pictures can be produced.
