Determine Which DataFinder Server Is Associated with Which Database File
Updated Mar 10, 2020
  • DataFinder Server
  • Data Management Software Suite
We need to delete or remove DataFinder Servers but when we do, the database file is not deleted and remains in the system folder. This file has a significant size and the name gives no indication of which DataFinder Server it is associated with.
Is there a way to determine which DataFinder is associated with the database file so we can delete the correct file when it is no longer needed?
The name of the database folder can be seen in the web browser address when you access the configuration page of the DataFinder Server. To access this screen, click on the gear of the server and select Manage.
Once in this page, the name of the folder will match the one in the server address. See image below.
