Plotting Multiple Channels With Different Start Time in DIAdem
Updated Jan 15, 2020
  • DIAdem
I have multiple channels or TDMS files that have different start times and I want to plot them on the same graph respecting the absolute time. How do I do that?
To visualize each channel with the correct start time in a graph in the VIEW tab, follow the steps below?
  1. Drag and drop all the channels to the graph in VIEW tab (Use CTRL button to select multiple channels before drag and drop);
  2. Right click the X-axis and select Display...
  1. Select Absolute in Time axis;
  1. Click the Ok button and you will have the data in an absolute x-axis.
