How to Run a VI in my C# Application Using LabVIEW Runtime
Updated Jun 25, 2020
  • LabVIEW Runtime
Programming Language
  • C# .NET
I have a C# application that runs a VI using the Call2 function. I have created an exe from my application and when I run it, LabVIEW always opens to execute my VI. But, as it is an executable, I don't want to see this window, I want to run my VI with the runtime.
How can I do that?
As you use C#, you can build a .NET assembly containing your VI and then call it in your code instead of using LabVIEW functions.
As the .NET assembly is a DLL, so a compiled object, it will be executed using runtime.
Please follow that link to learn how to build a .NET assembly using LabVIEW: .NET Interop Assembly Properties Dialog Box
