NOVALUE Text Partly Displayed After Value Update
Updated Feb 4, 2020
  • DIAdem DAC Kit
  • DIAdem DAC Bundle
  • DIAdem
Other
  • DIAdem Visual
  • When I use a table in DIAdem Visual, the NOVALUE entries are wider than my table columns.
  • When I overwrite a NOVALUE entry with a number, I can still see a part of the NOVALUE text.
This behaviours occurs due to your format settings for the table.
Since NOVALUE has 7 characters, you should use a format setting like ddd.dddd with also (at least) seven positions.
If you want to delete the NOVALUE entries completely, you can use the Signal Copy block, which has a paramameter settings to overwrite NOVALUE with a selectable value.
