Measurement Studio Licensing Errors When Compiling Code
Updated Jul 26, 2022
  • Measurement Studio
  • When I compile my project, a LicenseException is thrown.
  • I have updated my computer details for Volume Licence Manager and it has issued me with a license to compile my application. However, I cannot compile it as I receive an error saying that my license is not active.
  • NI graphs and controls do not show up correctly in the designer view (WPF) and show error code XDG0062.
  • I have an active license but when I try to compile the project I get the following error:
"NationalInstruments.Controls.Internal.WpfStandardLicenser" is unlicensed.
  1. The libraries you are attempting to use are not included in the edition you have activated. Use NI License Manager to change your licenses, enable evaluation mode, or purchase a different edition of Measurement Studio.
  2. The .licx file for your project is missing or incorrect. Refer to the following article for more information on updating the .licx file content either manually or using Visual Studio-integrated tools: How to Generate a License File in Measurement Studio.
  3. You have a compile-only license, and your .licx file is not up-to-date. In this case, you need to update your .licx file manually. Use the following page to generate the .licx entries manually for your Measurement Studio project: Create a .licx File for My Measurement Studio Project.
  4. Your license is in an invalid state. You have three options:
    • Use NI License Manager to activate your licenses
    • Use the Measurement Studio menu to activate your licenses
    • Select Evaluate Products in the Licensing and Activation dialog box if you are still within the Measurement Studio evaluation period.
  5. Update the NI License Manager to the most up-to-date version.
  6. If none of the previous troubleshooting steps fix the issue, uninstall Measurement Studio and Visual Studio and perform a clean installation of both components.
For Licensing Errors in Measurement Studio when designing, running, or deploying your code you can download the manual from the following link and take a look at the Troubleshooting Measurement Studio Licensing Errors section: Measurement Studio 2019 Help.
