My sbRIO 9607 Does Not Detect Ethernet Connection
Updated Jun 16, 2021
  • sbRIO-9607
I have created a mezzanine card with Ethernet components to create an Ethernet bridge with the sbRIO-9607. When I connect the cable to the card, it does not detect the connection so I can't communicate with the sbRIO.
What can I do to fix this issue?
You can check the datasheets of the components to make sure that you did not forget anything in the circuit, for example capacitor or resistance.
For the sbRIO-9607, please see the NI sbRIO-9607 Mezzanine Card Design Guide , it will help you to design the circuit.
