You may get all failures in CA121~CA127 at all positions.
It happens because the APDU response [I(0)0] does not have the status word(0x9000) at the end of the response.
It could happen because your UICC or e-SIM does not have the EMV appplet data inside.
It is not a hardware problem (including ANT) and is only caused by UICC and e-SIM.
Here is the verdict criteria of Response test (CA121~CA127, CB121~CB128)
- The PICC shall answer correctly to each command
- The transaction will be considered as successful when the PICC answers all transaction sequences and when each R-APDU contains a status word equal to 0x90 0x00.
There are two solutions:
1. Using UICC(SIM) which has Payment applet data
2. Go to " Option" in the Test suite configuration Tab
3. Delete all "APDU List" by click "x" and Click the "Save & Apply"
4. Run test : In this case, Test suite doesn't care about the status word (0x9000)
