We are making the addition of the XCPplus structure in A2L files. I'm using the ECUMC Toolkit, which should have support for this. However, when I try to Connect, I get error -301007
Error -301007 ocurred at File.vi
Possible reason(s):
ECU toolkit: (Hex 0xFFFB6831) The communication parameters for the ECU are not properly initialized.
The parameters are probably not defined in the database file.
Solution: Set the communication parameters for the ECU using mcSetProperty before connecting to the ECU
![](/servlet/rtaImage?eid=ka03q0000012DCD&feoid=00N0Z00000HEWRk&refid=0EM3q00000167Q0)
