Unable to Find Log Files Generated from NI-XET Bus Monitor
Updated Dec 18, 2019
  • NI-XNET
I am trying to log the frames received at my CAN port via NI-XNET Bus Monitor, however, I am am not sure where to find the log files generated:
The information for the destination of the Log files in mentioned in the Help document. Click on the Help button in the Logging Settings to open detailed help for Logging Settings:
If you stream your network data on a remote target with the NI-XNET Bus Monitor, you can select only the filename. You cannot change the file path, as the logfile is stored in the default NI-XNET folder on your remote target. Use any FTP program to download the logfile to your local host for further analysis.
