Can I Get TestStand in a Different Native Language?
Updated Jan 7, 2020
  • TestStand
  • Can I change the language that TestStand uses?
  • I would like to use a language other than English in TestStand
  • What native languages are available to use within TestStand?
TestStand is only available in English, there isn't anyway to change the entire language the software uses.
The most suitable workaround available would be to localise the language that TestStand uses by manually modifying it. This involves modifying the viewable strings in the resource string .ini files. The details for how to do this are specified in the tutorial : Localizing TestStand to Different Languages.
