This issue is caused when one of the required packages of NI-Switch is missing. The instructions about how to install NI-Switch properly can be addressed in the readme file of the corresponding driver version, which can be found in its download website. For this specific error, the missing component is installed by ni-switch-daqmx package, so it can be fixed just by running the following command:
- yum install ni-switch-daqmx
